brownsfn2
I have never turned antler. I really like acrylics much better. After having a slow month I agreed to do a set of pens. One in Antler and one in Buffalo Horn. I placed an order with a vendor and received the antler and buffalo horn. I ordered extra as I am sure to screw up.
The antler I got was a much larger diameter than I thought it would be. I am turning a Jr Gent II so I hoped to have a piece that was not much larger. The pieces I have are 1-1.5" in diameter. So there is a pretty big "pith" running down the center and just about 2mm of hard outer shell. I decided that the soft part could be turned so I drilled down the center and glued in a tube.
Once I got close to final dimensions I noticed a lot of pitting due to the softness of the material so I added CA to it to harden it all up. I turned it a little more but had to walk away because I was so frustrated with the look.
I thought it looked terrible. It did not have that nice off-white look to it. I read the article in the library that talks about antler and it said that I should not let the pith show through to the outside. With these pieces of antler I have I just cant see how that is possible to do though.
Anyone have any advice? Is antler just that way and I am not familiar with it?
ANy help is appreciated. Thanks so much!
