bgray43050 said
"I know that you can just drill ALMOST until you break through, and then cut off the waste. I don't like doing this.
If you have a blank with beautiful grain that you want to continue from cap to barrel, then this cut interrupts this continuity.
My 2 cents...drill on the lathe."
I agree with both of your points, but there is also another method
I do my drilling, both on the lathe, and on a drill press. I agree, the I hate to break up the grain, or pattern on an acrylic blank. If I want to prevent blowout with the grabbier acrylics, I cut the blank to length, leaving room at both ends of the blank for an overshoot. Then I drill both halves starting at the center, and stop just short of the end of the blank. This way, I save my pattern, and I get to preserve the end of the blank. Just another way of accomplishing the same thing.
For my tougher acrylics, I find myself using the drill press, because I can go back and forth easier, and eject the chips better. My lathe has a very short quill travel, and I have to move the tailstock back and forth to clear the hole as I am drilling it. If I had a different tailstock, I would probably use the lathe method more often.
Dave
(Edited because I posted before I finished writing message...)
