mdburn_em
Greeting,
I have an Atlas Pen purchased through ArizonaSilhouette. I am having difficulty getting the ends of the wood so they are flush. Typically, one side (maybe 60 degrees of the 360 degrees) of the pen will be flush the rest will be proud. I have tried to mark on the picture where it's flush. I have a jet mini lathe less than 2 months old and I'm using stock equipment including the stock tailstock. I am also using a Jet pen mandrel. This is the first Atlas pen I've made. I've made about 10 cigar pens and maybe 10 slimlines. When I tighten up the nut and begin to rough out the pen, it frequently catches because I am trying not to over-tighten. Is this possibly a problem with not having a 60 degree tailstock?
I attempted to put this in the critique section but it appears to be locked. I hope this is ok.
Thanks in advance for any help.
