I have had many friends come back within 1-2 weeks on pens that I have made ALL having the same thing to say about their pen. "It was very nice...blah blah.. I've noticed the wood has split on it..." Yeah, the first pen, I thought, hmm.... what happened. The second pen left me thinking, what are they doing with the pens. The third and fourth pen left me thinking, OMG what am I doing. The fifth, sixth, and so on ....
Here are my steps, I am hoping this can be resovled as this has happened to cigar and Majestic style pens. Woods including Cocobolo, African Blackwood, Bloodwood, Osage Orange, Snakewood *yeah I knew that would happen, ligum vitae, and stabilized boxelder. Koa... never cracked.
Measure blank with the tubes and make my cutting marks.
Cut on a bandsaw
place blank on the pen vise tight but not tight enough to hear a crack
pre-drill with an 1/8" bit backing the bit up to not over heat
drill with the 10mm carbide tip bit backing the bit up to avoid clog and over heating*for cigar pens and appropriate bit for majestic
insert appropriate tubes after sanding the outside with 400grit paper and swirling CA thick on the ends before slipping them into the blank.
Spraying the ends with activator to harden the glue that overflows on the outside from putting the tubes in the blank
place blanks back on the pen vise for barrell trimming
trim barrel backing of when I see the slightest bit of smoke
apply blanks to the bushing and place on the lathe.
I have used a brass tight nut to secure the blanks on the mandrel and I have used the mandrel saver, both are yeilding the same result.
I have turned the wood at 1150 and 650 rpm and have yeilded broken the same results.
sand 180, 240, 320, 400, 600 but not to tight to avoid heat build up. Sanding was down at 2250rpm
from here I have used two different approaches to finish... both yielding the same cracks...
1. using eee ultra two coats on a cotton cloth
Following up with friction polish on a cotton cloth *2 coats
2. applying CA and Activator... 1 coat CA, 1 spray activator, *8 coats
sanding 1500 to 12,0000 wet
applying plastic polish
BOTH of the finishes have yielded my cracks.. it has gotten to the point I am a bit embarrased to chat with these friends due to the "hey, my pen........" I have nearly sworen off wood pens entirely. Acrylics so far have yielded much better results. How can I correct this problem? I understand that many of you will reply with the "I am not there to see the pressure, speed, etc that you have used so I can't give the best advice." I have documented every step to the dot how I do stuff minus the pressure that is applied with the bandsaw, drill press, barrell trimmer, and sand/eee/polish. I am hoping this will help.
Jeremy
Cut on a bandsaw
Jeremy
