ahoiberg
does anyone know exactly how these modified slimlines are put together?
they almost look like a sierra, with a small piece of wood toward the nib and then a larger piece (negating the use of a centerband) from the smaller piece all the way to the finial/clip.
i'm just curious to know how/where the transmission is pressed in because obviously the refill would stick out about 3 inches from the nib if you pressed it into the lower blank.
i'm also assuming you have to use custom made brass tubes?
thanks!
thanks!
