underdog
So I got a bunch of pen kits from Exotic Blanks, and they threw in a couple of those cast blanks as freebies. (Thanks Exotic!)
Then my wife saw the purple acrylic blank (madreperlato purple) and wanted it for her dear friend, (who has truly been a friend to call and visit and check up on us, in our time of grief.)
I have been saving this one til I got through with all the other wood pens I was turning for friends and relatives who helped through this time as well.
So last night I drilled out the blank using the slowest speed on my drill press (didn't want to melt it as per some advice here).
But then I wondered what was best glue to use... and what tool to use, and whether finish is necessary.. and, and, and...
I called a buddy of mine and he says that he would use epoxy to glue the tubes in, and be sure to paint the tube first because the transparency of this acrylic can really surprise you..
So I did paint the tube with some white enamel, and I let that dry overnight.
Tonight I may try gluing in the tube... What's your advice for me?
Epoxy? Super Glue? What?
And did I do the right thing by painting the tube? Will the glue stick to that?
When it comes down to turning the blank, does a scraper work best? Or can I used the roughing gouge to knock the corners off then use a skew?
And now that I know to wet sand, is that all I need to do? Or do you all put a finish on this stuff?
Thanks for all the help you guys have given me in the past... It's really appreciated... I'd best post a coupla pix of the stuff you helped me do, eh?
