Originally posted by ctEaglesc
<br />
Originally posted by sandking
<br />i was wondering how many of you turn the lathe of between grits and sand with the grain? For lighter woods I don't find this necessary but on darker ones I can't seem to get the previous grits sanding marks out without doing this up to 400 grit. After that I use MM and you can't see them, then off to the tripoli then white diamond before putting on a CA finish.
Try it twiththe lathe off and with the grain one time.
You will see a difference in the appearance of the wood you never knew.
It is like looing through a dirty window.You don't know how dirty it was until you wash it.
It is not something that explains well in print, but I have seen work done by others at craft shows and consignment store.
I can tell the diffrence and I am just about blind.
