wortmanb
I just turned an afzelia wood fountain pen, and while the process was highly enjoyable, I think something's missing from my technique.
The pen looks wonderful, but my fingers can make out areas where the pen "ripples", for want of a better term. It's as if the various grains in the burl kept me from achieving a perfect, uniform thickness, and there are instead areas where there's the slightest of dips when you feel the cap or tube from one end towards the other.
I knew there were variations, but I foolishly assumed I could knock down the high points when sanding. That didn't work very well -- mostly, the Abranet just followed the contours and I got nicely sanded ripples.
I'm currently using 3/4 and 1" gouges for pretty much everything, and I've been pleased with the results on most blanks. I occasionally grab a detail gouge for rolling over the ends, but I'm not particularly adept with that or with a skew, so I probably need to practice on some waste blanks to get the hang of it.
What technique(s) should I work on to help avoid this problem on my next burlwood pen?
