JimMc7
I had a couple of Sierra transmissions which were stiff to a fault to turn. I made the mistake of spraying some WD-40 in them and now they are too loose to a bigger fault. I searched and found a reference to "motion control grease" or damping grease but didn't find anything conclusive whether this actually worked in correcting the "too loose" problem.
Ernie at BTW sells replacements for the 2.37" Sierra transmissions but he's currently out of stock. I contacted Berea and they said they don't sell replacements but I should try Vaseline (a bit ironic, I thought). I tried to push some in the transmission with no noticeable effect other than making a mess. I also tried some blue Loc-tite and that worked for about 10 twists.
Anyone else have such a problem and a solution?
Thanks!
Thanks!
