I just turned one of El Mostro's bloodwood cross, ivory aluminite pens and am now ready to finish. If it was solid aluminite I would simply wet sand with MM and polish. since the bloodwood is there was wondering if anyone had any tips. I don't want to put a CA finish over the aluminite if I can avoid it. If I wet sand and just leave the bloodwood exposed would that be okay or would the moisture from the sanding mess it up. Should I rub in a little ca to seal the cross and then wetsand with MM.
any tips would be greatly appreciated.
