jleiwig
Do you turn under the kit diameter before applying your CA finish?
The reason I ask is because I turned to the diameter on my pen I finished last night and finish sticks out around all the findiings about 1/32" of an inch.
You can tell that it is just pure finish sticking out past the findings, as in one spot under the clip where I chipped the finish it is flush with the findings.
