dickhob
I give up. Finished a Berea Elegant American BP today and carefully assembled it per instructins. The transmission does not work correctly. I've read in other posts that there have been problems with this, but I simply don't understand what is wrong or how to fix it.
I disassembled the top, made sure the barrel was clean. I checked that the refill works smoothly through the nib. I've reassembled the top again. Right now the bp tip is in writing position. In order to retract it I literally unscrew the top from the center ring, leaving a 1/16 gap between the center and the blank- totally unacceptable.
I've read all the threads (I think) and checked AS and Berea web sites. I can't figure this thing out. If someone can explain what is happening and how to correct it I would very much appreciate it.
Dick
New Milford, CT
Dick
New Milford, CT
