Hello, I have noticed that after hand tightening the mandrel nut barely snug, I spin and the mandrel thumb screw nut gets very tight on its own-so tight in fact that I need pliers to loosen the nut. This can effect blow outs on the lathe because it locks the barrels. My setup is normal bushings and a washer. I was thinking that may be I need to add some 7mm bushings or maybe that the bushings aren't completely flat on the sides, or the mandrel is bent?
Does anyone have any ideas on why this occurs and reccomendations on how to avoid it?
Thanks in advance for replies,
Nick
Nick
