How is the barrel trim adapter tube used? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-07-2018, 10:10 PM   #1 (permalink)
bsshog40's Avatar
Photos: 7
Default How is the barrel trim adapter tube used?
I bought this legacy barrel trimmer set. The adapter tube is suppose to be used for 8mm trimming. Has anyone used this or know how it's suppose to be used? The kit has a 3/8", 7 mm, 8 mm and 10 mm pilot shafts. Thanks!
Bobby
__________________
Bobby
My Original Music
https://www.youtube.com/user/bsshog40/videos
bsshog40 is offline   Reply With Quote Top
Old 11-07-2018, 10:19 PM   #2 (permalink)
Mr Vic's Avatar
Photos: 2
Default
Just slip it over the 7mm shaft when trimming an 8mm tube (slim line pencil). NOTE: If pointed down while drilling it could slip off.
__________________
Mr Vic
Keep the shiny side up and the greasy side down.......
President Pikes Peak Woodturners - AAW Chapter
Mr Vic is offline   Reply With Quote Top
Old 11-07-2018, 10:45 PM   #3 (permalink)
bsshog40's Avatar
Photos: 7
Default
Thanks Vic. I wonder why the set would have an 8mm shaft but you have to use the adapter on the 7mm shaft?
__________________
Bobby
My Original Music
Advertisement
Old 11-08-2018, 07:12 AM   #4 (permalink)
Photos: 18
Default
Did you buy the set used? The adaptor is just a 7mm tube, they fit inside the 8mm pretty easy and the previous owner figured out this is a good way of using an 8mm kit without disassembling the cutter making it easier to go back to work on slims.
__________________
Stabilized blanks and more
Gary Beasley is offline   Reply With Quote Top
Old 11-08-2018, 10:11 AM   #5 (permalink)
Paul in OKC's Avatar
Photos: 6
Default
The adapter tube is for larger than the shaft included in the kit. For larger tubed pens, you would make a 'blank' that is turned to the ID of the tube and then use as normal. I do this for all my pens as I only have the 7mm shaft, and have made a couple of different diameter adapters for what I make using extra 7mm tubes.
__________________
Paul in OKC, OK
Romans 12:2
Do not conform to the pattern of this world, but be transformed by the renewing of your mind..........
Paul in OKC is offline   Reply With Quote Top
Old 11-08-2018, 08:07 PM   #6 (permalink)
bsshog40's Avatar
Photos: 7
Default
Well I was doing some 8mm pen kits. I bought the set new from the woodturning store. It has an 8mm shaft in the kit but when I went to barrel trim, it started to marr the insides of my tubes. I decided to just clean the glue off the ends with it and used my 7mm shaft on the barrel trimmer to trim the ends. I actually think the shaft was not exactly straight as I was getting a slight wobble with in on my drill press. I turned it all around the press and readjusted the barrel trimmer to the shaft but never could get rid of the slight wobble. None of the shafts are marked but it fit in the tube just as good as my 7mm shaft fit in the 7mm tubes. I'm betting a defective 8mm shaft.
__________________
Bobby
My Original Music
Old 11-08-2018, 09:18 PM   #7 (permalink)
Mr Vic's Avatar
Photos: 2
Default
Is the tube brass? Mine is steel. They might have swapped a 7mm tube for it.
__________________
Mr Vic
Old 11-08-2018, 09:45 PM   #8 (permalink)
bsshog40's Avatar
Photos: 7
Default
Quote:
Yes sir, it is a brass 7mm tube.
__________________
Bobby
My Original Music
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
