Honeycomb question - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-31-2018, 09:59 AM   #1 (permalink)
Photos: 5
Default Honeycomb question
I want to make a pen using aluminum honeycomb. I was told to soak the metal in white vinegar for about one hour to "rough up" the metal and allow the PR to stick better. Blank looked good but as it was turned the very small sections on the outside fell off. Now it has been suggested I use the acid bricklayers use to clean bricks. Any help would be appreciated.
tomtedesco is offline   Reply With Quote Top
Old 03-31-2018, 11:26 AM   #2 (permalink)
Photos: 0
Default
With the alun honey comb blanks I have cast we're not cleaned with any special way, blow them off , insure they are the same temp as the alumlite(70 degrees plus), pressure pot for 4 hours at 60 psi and never had any bowl out.
I only turn my blanks with. Very sharp skew.
That is what I do, hope it held.
Charlie
Dieseldoc is offline   Reply With Quote Top
Old 03-31-2018, 11:50 AM   #3 (permalink)
Photos: 161
Default
I clean mine with Kurd Kutter metal clean and etch
https://www.homedepot.com/p/Krud-Kut...E326/203396817
Even with that, I have not had much luck casting in PR, alumilite works much better.
Cwalker935 is offline   Reply With Quote Top
Advertisement
Old 03-31-2018, 01:23 PM   #4 (permalink)
jttheclockman's Avatar
Photos: 83
Default
Epoxy resin will work better but I am guessing alumilite will work too because it does not shrink and pull away from the metal.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 03-31-2018, 01:37 PM   #5 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Lol. I bet Kurds on the aluminum would make getting anything to stick to it a little ďcheesyĒ.
__________________
New Contest for 2019 BASH!
Take a look at the rules for what is considered the fairest, best balanced competition for all members:http://www.penturners.org/forum/f18/...-rules-157766/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 03-31-2018, 02:32 PM   #6 (permalink)
Photos: 0
Default
Quote:
Interesting comment about using Epoxy resin as I have found out Alumlite works 100 percent of the time. I sure Epoxy resin would work too. However when gluing in tubes which are pre painted, with CA I get a blotchy looking color from the tube. When using Epoxy with colored tubes and putting color in the Epoxy before gluing in tube the blotchy problem is gone, tubes stay tight and don't have any blow outs. To insure that the ends of tube-blank stay solid I will after turning 50 percent of diameter put a little CA on both ends, then do the same thing just before reaching the correct diameter of the tube.
For sure making Alum Honey comb pen is a real challenge to get good.
Old 04-01-2018, 06:52 AM   #7 (permalink)
Rachgard's Avatar
Photos: 0
Default
I have turned about 6 pens from honeycomb blanks I have made myself. One of which I turned down to a slimline, which I think was almost a dumb idea, even though the pen ended up very pretty. I do not clean the aluminum before pouring. I do use alumilite and a pressure pot. I also use a carbide roughing gouge and only take off a tiny bit at a time. I go into these blanks knowing that theyíre going to take a while to make. I stop roughing when Iím about 1/8 of an inch out, or if thereís chunks flying everywhere, Iíll stop sooner. Then I take off material with 80 grit sandpaper. Like I said, it takes a while. With this method, Iím able to consistently do bigger pens with no blowout. But with the slimline I found that even with the gentle removal method I could still see separation, so I had to part off the ends and glue everything again. I probably could have prevented it had I put on some thin ca halfway through like dieseldoc said. I usually ca the ends after trimming them. img_9769.jpg
I think alumilite helps, but you have to be really cautious on the removal as well.
Rachgard is offline   Reply With Quote Top
Old 04-01-2018, 08:38 AM   #8 (permalink)
Photos: 5
Default
Quote:
Originally Posted by Rachgard View Post
I have turned about 6 pens from honeycomb blanks I have made myself. One of which I turned down to a slimline, which I think was almost a dumb idea, even though the pen ended up very pretty. I do not clean the aluminum before pouring. I do use alumilite and a pressure pot. I also use a carbide roughing gouge and only take off a tiny bit at a time. I go into these blanks knowing that theyíre going to take a while to make. I stop roughing when Iím about 1/8 of an inch out, or if thereís chunks flying everywhere, Iíll stop sooner. Then I take off material with 80 grit sandpaper. Like I said, it takes a while. With this method, Iím able to consistently do bigger pens with no blowout. But with the slimline I found that even with the gentle removal method I could still see separation, so I had to part off the ends and glue everything again. I probably could have prevented it had I put on some thin ca halfway through like dieseldoc said. I usually ca the ends after trimming them. Attachment 175014
Thanks for all the reply's, sounds like PR may not be the way to go. Interesting idea about sanding to final diameter, may have to give that a try.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
