Homemade CA Accelerator?
bgray
Milan, OH
I remember once there was a recipe posted for a homemade CA accelerator.
Anyone know where this is? Does it work?
Thanks.
jwoodwright
Anchorage, Alaska, USA.
How's this:
Make a solution of water and baking soda for a pretty good accelerator. but it does not evaporate as quickly. any leftover water may accelerate when you don't want it too. mix up a tablespoon in a cup of hot water and put it in a mister bottle . works like a charm in a pinch, and its foam safe. but still not as quick as store bought.
CA is inhibited from setting by being slightly acid. Anything that reduces that acidity a bit will cause the CA to set up. Water reduces the acidity by dilution. The CA usually sets by interacting with the materials it is bonding. The material or its residual moisture reduces the acidity of the CA and it sets. This is why CA won't set on foam by itself, nothing to reduce its acidity. Baking soda, either as a dusting of powder or as a solution, will reduced the acidity and the CA sets up. Commercial accelerators are something more complex to be persistent but they do the same thing. I use baking soda solution myself.
redfishsc
North Charleston , SC
If you are needing a CA accelerator for a CA finish, research the CA/BLO method of pen finishing--- BLO is an effective CA accelerator.
(BLO= Boiled Linseed Oil).
leehljp
Member Liaison
Tunica, Mississippi,
Originally posted by ozmandus
I don't know what is in the commercial accelerator, but it smells like DDT to me.
Chuck,
You are letting on your age! [}:)] I think you are right - I have been wondering what long ago scent the accelerator reminded me of.
ON the main topic - BLO is a mild accelerator.
Jarheaded
Fairfield county, CT, USA.
Has anyone used the accelorator from Hobby Town? I needed some quick and they are close, it smells better but seems to leave a residue of some sort. It wipes away, but that seems to defeat the purpose somewhat.
follow3
Hampton, VA
I am with bgray, I would love to know what the actual chemical is that is used.
Aren't any of you super duper smart guy chemists? Maybe you could do a chemical analysis of the product. How about any CSI people...you couldput it in one of those spectragraph machines and tell us what it is.
Just ideas. I'm not sure what it is, but from the sound of some of the other posts, you better not spray it on your apples!
Steve
dachemist
Albany, NY, USA.
For those who are curious, here's the active ingredient in the accelerator Whayne referenced above:
http://en.wikipedia.org/wiki/Toluidine
It works by starting a polymerization reaction. A fun way to picture it would be a line of dominos. When they are standing up and separate would represent the uncured ca. When they have fallen down and are touching each other that would represent cured ca. The toluidine is the finger that pushes the first domino over.
follow3
Hampton, VA
So, is there a common name for this chemical? If so, where can it be bought?
In the description you linked to, there seem to be 3 types of the same base chemical, which is the correct one for this application?
Thanks,
Steve
drawknife
Smyrna, Tennessee
I've have seen toluidine listed with toluene. Don't know what the difference is but I have a lot of toluene. Would they perform the same function Mike?
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
I would stay away from toluidine except as it is found in the accelerators.
Toluidines are used in the production of dyes. They are a component of accelerators for cyanoacrylate glues. They are toxic and are suspected human carcinogens.
(Emphasis added)
Nashua, NH, USA.
CA fumes are bad for you. Accelerator is bad for you.
Do any of you use a respirator when you are putting on CA/BLO finishes? Or is a dusk mask adequate to stop the CA from getting to your lungs?
If you do use a respirator, any recommendations as to type and brand?
dachemist
Albany, NY, USA.
Steve, toluidine is the common name. As far as I know the only place to buy them is from a chemical supplier and they don't sell chemicals to individuals. Any of them should work though I would expect either the middle one or the one on the right to be the most commonly used.
Terry, toluene is similar to toluidine as the name implies; however, they are different things. The only difference is toluene does not have the amino (-NH2) group. Toluene would not work because the amino group is the part that reacts with the ca.
I'll second Lou's warning about avoiding toluidine outside of accelerator because things like toluidine tend to be absorbed easily through the skin.
As an alternative the baking soda, plain household ammonia (the stuff used for cleaning w/o scent or detergent) should work. Unlike baking soda, ammonia will evaporate. However it's still mostly water and may need dilution out of the bottle to avoid reacting too aggressively.
Timbo
Kill Devil Hills, NC USA.
I had to get to the last post to set me at ease. Thanks dachemist. I'm a former lab rat that worked many years for a large specialty chemical company. Out of curiosity, I researched the CA accellerater active ingredient several months ago. Once I found out what it was, I decided it was not worth trying to make my own, even if I could get my hands on it. Handling many chemicals in a concentrated form can be very dangerous, and even fatal[xx(]. NO ONE should be attempting this without proper training. I third Lou's warning.
loglugger
Lebanon, Oregon, USA.
This is what I have read on the wood forms. Acetone was the main thing they came up with a year or two ago to use as a CA accelerator. I have never used a accelerator as the CA dries to fast for me most of the time anyway and often wandered the advantage of using the accelerator. Been told that it makes the CA brittle and will brake eaiser with a sharp jolt as if you droped the pen.
Bob
penicillin
Wow, as long as it has been since they banned DDT your nose has a long memory! [:eek:)]
DDT remains in limited use elsewhere in the world, especially in places where malaria is a greater concern than DDT contamination.
I have lived in places where DDT was the active ingredient in household bug spray. That was many years ago, but it was long after DDT was banned in the US.
egnald
Columbus, Nebraska, USA
My father was an avid believer in the benefits of DDT. After VJ he wiped out the bed bug infestation in his folk's house with just a little DDT. He was convinced that the only reason there is still Malaria, Dengue, and West Nile in the world is because DDT was banned. I think India is the only place that still manufactures and uses it. - Dave
pshrynk
Lake City, Minnesota
The ortho isomer is produced on the largest scale. Its primary application is as a precursor to the pesticides metolachlor and acetochlor
Which would explain the DDT nasal memory situation, probably.​
