ChewTerr
Hey,
I've only turned a dozen or so pens, so I am still figuring things out. I recently started turning a piece for a Sierra pen. As I was rounding it out, I started seeing a lot of holes within the wood. I could tell that some went clear through to the tube. I had heard reference to people filling in imperfections with CA/superglue, so did that for practice, using some random Harbor Freight super glue. This did smooth out/fill the holes, though it also sunk into the wood and darkened it a lot in the areas I poured it. I turned/sanded the darkness out to end up with a relatively smooth blank. This catches y'all up and brings me to my two questions:
1) What do y'all do when presented with hidden holes in the wood that are deep enough to show the tube? Is there a way to fill them, or is the tube just going to be visible?
2) What should I do with this blank? I could jam it on a Sierra kit, but seeing the tube through a few little holes seems pretty... rough. Is it worth wasting a kit on, or do I toss it?
Thanks!
-Will
Thanks!
-Will
