GregHaugen
I was curious what methods are people using to hide the tube in acrylic pens that could show through? Also what adhesive are you using, something different than you normally would or the same??
Thanks.
Thanks.
Here's what I do and before I start I know I'll get,"That doesn't work, CA dissolves"...etc...
Here's what works for me. I use acrylic craft paints like you'd buy at Walmart, Hobby Lobby, Michaels, etc... Between my pen making and my wife's craft stuff we've probably got 75-100 colors.
I ALWAYS assume that the tube will show through, better safe than sorry later on.
I paint the inside of the blank using a Q-tip. This prevents the glue bubblesfrom showing through even the most translucent blanks.
I also paint the tubes if in doubt of the translucence of the blank.
I let anything I've painted dry, or cure overnight. I usually work in batches so waiting isn't a problem, I've probably got 40-50 different acrylics and other plastics waiting to be turned :biggrin:
I glue my tubes in with thick CA and hit them with a spritz of accelerator
I allow these to sit over night and then trim the wax out of the ends and square the blanks
The ready to turn blanks then go on my "ready to turn" shelf over the lathe
I also experiment using different colors to "change" the look of the finished product. You'd be surprised what painting something a diffrent color inside will do for the look of a pen.
Someone else mentioned in another post about painting the white blanks from WoodCraft. I too do this with several either pastel of bright neon colors. I have a whole line of perfume pens which I call my Glacier Series. They've turned out to be very popular at all our shows.
It all depends for me, I have used a range of things from replacing the brass with chrome/white/chameleon tubes, I sometimes paint the tubes and/or use fingernail polish to paint inside the blank. Heck, I've even experimented with using MIXOL color pigment and/or dry powder pigment and have mixed that into the epoxy or CA I'm using. All have varying effect, some spectacular, some cool, and some not so cool .
Mick, what kind of paints are you using??
