swirlman
Got my pot set up with venturi vacuum pump ready to go. Question is do you put your solution with blanks directly into the bottom of the pot or can you put it all in a seperate unclosed container in the pot then pull your vacuum? I'm thinking I could keep the pot a little cleaner by using a seperate solution/blank container inside the pot. Also I thought I would try using Minwax Wood Hardner to start out, anybody else tried this product? If so with what results? Any help would be appreciated. Thanks, swirlman
