thewishman
Last March, a couple of skilled and generous turners helped me to get started in this wonderful and terrible "hobby." I learned enough to make some pens and sell enough to buy my own set-up. Thank you, Billy and Alan!
Now, after joining a turning club, watching videos and getting advice from expert (though not pen-making) turners, I can barely make a pen. It was better when I was ignorant.
Is this just a typical sophomore slump? Will I be able to, "Break on through to the other side?" (My first ever Doors quotation)
A few questions:
When using my pen mill, I get a raised ring of brass that extends up from the inside of the tube. After I trim that back flush with a sharp knife, one part of the milled area is lower that the other 300 degrees of the circle. Is this a mill problem or an operator problem?
My unheated garage is my shop. Do the CA glues deteriorate in the temperature extremes of central Ohio?
Is there a better speed to turn burls? I had usually turned at 1800 rpm on my Jet mini, though faster speeds have both helped and hurt my results.
Some things I have learned:
Cheap sandpaper does NOT save you money
My HF 15/32 drill bit makes a hole that is TOO BIG for a baron cap
Most glaring mistakes are not even noticeable to other people
Chris
A few questions:
Chris
