I don't often rant about kits, but the Woodworkers Pencil ranks as one of my least favorite. This kit is, in my opinion, an abomination.
First off, <b>the components do not fit the recommended hole</b>! I understand that there is a work-around, using a tube from a cigar kit, but that's ridiculous. A design flaw is a design flaw, regardless of whether a work-around can be found.
Next comes the instructions. The length of the wooden part of the pen is 4-9/16". Why would I cut a blank to 5"? The outside diameter of the bushing is 0.465". <b>Why on earth is the blank size listed as 1" square by 5</b>"? Even with some playing room, a 5/8" blank is plenty big enough.
Then comes the coup de grace. In reading the instructions, they specifically indicate a 10mm drill bit and that it "<b>must be at least 6" long"</b>. I measured the 10mm drill bit that I have and it was too short. In order to be certain I had the necessary components to make the pencil properly, I ordered the "Starter Kit" which includes 2 kits, bushings and the proper drill bit. Guess what? <b>The drill bit the supplier sent is 5-1/4" long</b>! It gets better. <b>The hole drilled with the recommended bit is too small for the bushings</b>!
I can overcome these shortcomings, although I did have to do some consulting with Eagle in order to do <u>the right things</u>. The real issue here is that this kit is <b>poorly designed</b> and <b>poorly executed</b>. Add to that the fact that the "Starter Kit" violates the instructions and I come up with the word "abomination."
