MartinPens
I had a customer return his snakeskin pen. The cap and body tubes had bad cracks. (This was an El Grande kit, which I no longer use do to low quality parts) I disassembled them and took a couple macro shots to highlight what I'm seeing.
This pen was under normal usage - no, he didn't step on it, drop it, run over it or expose it to extreme heat.
I realize that I did not do anything to seal up the ends after trimming the tube. Could this be all it is? I'm noticing that the brass tube itself is actually cracked! There is also some type of reaction on the brass tubing causing some green buildup.
Any thoughts/solutions would be appreciated.
Martin
Martin
