First of all, welcome to the casting club with all of its complexities. I have probably produced every type of failure that can happen. Here is what I have learned:
(1): pressure casting has greatly improved my success rate. BUT, still having failures. Some of the skins look really cruddy and can't be used. Pre-pressure casting was about 40% success for me and pressure casting has been about 80% successful. I cast at 25-30 psi. Constant pressure is also important. I now hook up the air hose directly from the compressor to the tank and leave it connected. I use the pressure regulator valve on the com[pressor to maintain the pressure. At first I would hook up the hose, let the pressure build to 40 psi and remove the hose. When the pressure leaked down a little I would attach the air and let the pressure build again. Hooking the hose and leaving it seemed to help.
(2) Heat is a real problem. I cast 10-12 tubes per cast using 14-16 oz of resin. When I backed off to 3 drops per ounce my results improved greatly. I had one cast where the skins actually vanished...vaoprized...only brass tubes left in the resin.
(3) I have just recently started degassing the resin with a vacuum pump. This has improved my casting and now 100% of the tubes are useable. I have done 3 castings of 10-12 tubes and not a single tube was ruined. I have also reduced the pressure to 25psi.
(4) I have the tutorial almost finished. I hope to get it to Jeff sometime this week. I've attached a picture of my last casting.
Do a good turn daily!
Don
<br />
[/quote]
