gandsande
Help I have a client that broke the black plastic cap over the pump for this fountain pen. I am looking for one now. can some of you help me identify the kit? and if anyone has a cap to sell or can sell me a kit?
wow that was to easy. thank you. so second question anyone got a cap to sell or a kit? or at least know of someone in stock that i can order from so far looks out a stock
Woodcraft sells it as "El Grande"
Buy El Grande Fountain Pen Kit - Gold at Woodcraft.com
On my kit, the end cap *screws* into the part that is pressed into the barrel (does not "snap" on).I have tried the El Grande and Churchill. The problem is the cap at the end is molded plastic to snap on the part that is pressed into the barrel. that snap cap is what I need the snap ring into the barrel is intact and the cap is black plastic.
My customer is near to you then me actually. He currently lives in Vernon, B.C. funny how it all works....
You have to be aware that the El Grande part and the Ligero part are not compatible ... threads are different ... I just checked.
I stand corrected. I always thought the El Grande, Churchill, Ligero, and Cambridge were all from the same family and shared components. I appreciate knowing otherwise.
I just spoke to Wade and we have discovered while it might be a ligero there may be 2 styles to watch out for. this on has a brass/metal part pressed in then a plastic receiving piece is in that and the Black cap that covers the Pump end snaps on. This cap is the part I am looking for. Wade was thinking that maybe there was an older kit that I may have used from CSU that they later changed to a screw on cap. I cannot modify this pen for the screw version. any one sure of the or got comments on the snap cover type cap?
I have checked most of the threads in this "family" and it seems all (that I tried) are the same except the Ligero which is out on its own.
The threads may differ because the El Grande, Churchill and the Cambridge are Berea kits whereas the Ligero (at least the ones I have) are made by Dayacom and the older kits I had where from CSUSA.
Wade
