HELP!!!! HELP!!!
toddlajoie
Feeding Hills MA
Well, they are 3/8 tubes, so any bushings for similar tube sizes (Caraba/Atlas/Patriot, Classic American Rollerballs, etc) will hold the tubes on. I don't have any of the kits to measure the parts, so I cant say how close any of these kits may be, but you could always use them and a set of calipers (assuming that the bushings are smaller, it would be pretty hard to turn to significantly smaller than a set of bushings...) or if you have the live and dead centers, just turn between them with just the calipers...
RDH79
Rimersburg, Pa, USA.
Looking at the Library at the Pen kits and bushings artical it takes .586 &.485
I would say you could use a set of Carbara bushings and use a caliper.
Thats just a quick responce. I use the chart all the time trying to cross bushings
Hope that helps and you have a set of Carbara bushings
Pineville, Louisiana
To many tube sizes. Why not just 3-4 sizes?? anyhoo I will try and turn some out of hickory or some scrap resin.
I found some open end wrenches that worked good also, lots of checking though.
THanks ya`ll :O)
OH ..what is a carbara?
