Help !! with casing pens
pop1948
Midfield, Alabama, USA.
I would like to make some casing pens,cartridge pen liek the ones James Mann does with the whole casing. can anyone help with some instructions.javascript:insertsmilie(':D')
Big Smile :D
Skye
Rock Hill, SC
Here's the short version.
Drill out the rear of the casing.
Turn a wooden core on a 7mm tube to fit inside.
That's the short version. The long version is spread across about 300 posts here on the forum. Just do a search for the words "casing" or "bullet", you'll come up with lots of reading material.
jwoodwright
Anchorage, Alaska, USA.
David, make sure it doesn't have a Live Primer...
Used Primers are "punched" by the primer pin. The used primer must be removed. Thin punch or nail from inside cartridge, tap it out.
gerryr
Billings, MT, USA.
There is a tutorial by Don Ward in the library that has some very good information in it.
http://www.penturners.org/forum/topic.asp?TOPIC_ID=13621
leatherjunkie
Canby, Oregon, USA.
Originally posted by jwoodwright
<br />David, make sure it doesn't have a Live Primer...
Darn [:(] You just took all the fun out of pop1948 learning.[:D]
chances are if the shell has a live primer then the bullet is still attached to the other end. check with your local gun club about getting some used/fired(empty) shell cases. they should be able to point you in the right direction.
if not send me a pm and i may be able to scare up some shell cases for you.
