Carl Fisher
I have a few snakeskin cast blanks that have resin that built up inside the tubes. I tried to clear one out by running a smaller sized drill bit through to clean out the bulk, but it grabbed and cracked the cast. Filing it down seems to risk filing the tube out of spec which would cause the pieces not to fit snug.
Not sure what else to try. I guess maybe progressively larger dowels with sand paper, but again I'm afraid of sanding too much of the inner wall of the tube on the far side if it's angled in any way.
