Need some advice from the more experienced to a relative newbie.....
Now, I have to learn how to glue the tubes into the blanks better so as NOT to get glue down the inside of the tubes and/or how to clean 'em out better when I do.
Also, I must cut my blanks more accurately so I have minimal corrections to make on the length of the blanks before turning.
Any suggestions????
Thanks in advance!
Joe
Hi Joe,
Gluing the tubes without getting glue into the inside of the tubes is always a trick think, many people use a slice of a raw potato (1/2" or so) and push the tube into into cutting a perfectly seal to stop the glue to get in, this normally only need to be done on one end of the tube, the front end of it.
Cleaning any glue from the tube is normally easily done by using a brass shotgun barrel cleaning brush. You can also use a rolled up piece of sandpaper by itself or rapped around a round stick to made a glue cleaning rod.
One other important detail while cleaning the brass tubes is to "de-bur" the inner edge of the brass tune for easier kit part installation, voiding splitting of the barrel/blank when pressing it all together. This bur remover can be found in any firearm store, which does any size tube, from the inner and outer edges if necessary. There are a few other tools that can do this job.
The gluing of the tubes themselves, are normally done by using thick CA or Epoxy 5 minute glue. I prefer the epoxy as I do prefer to use a slightly oversized drill bit (just a tinny bit) so that allow a easier tube insertion and at the same time, leave behind sufficient glue to fill and give a good and solid contact.
The best way to insert the tube into the blank is to rub a small portion of the glue inside the blank and then a quick coat on the tube that should have been cleaned roughed-up (tune gluing surface) with some low grit sandpaper, prior to the gluing process. Then using your fingers or a proper inserting tool (available at pen stores) you insert and rotate the tube as you go, this allow for the glue to spread uniformly inside the blank.
Take into consideration that, if you are using 5 minute Epoxy resins, you have to have everything ready at the time of gluing, you have enough time to mix the glue for both tubes if the pen has 2 barrels, or do 2 x single barrel pens but no more than that. If you don't feel confident with mixing the glue for both barrels at one time, simply do one at the time or use a Epoxy with a longer curing time...!:wink:
After the tubes are glued and set/dry then, all the right steps have already been explained by other members to you...!:biggrin:
Good luck!
Cheers
Cheers
