PTsideshow
What height should the lathe spindle be from the floor. I have found enough different spindle heights to make it confusing on the specs for the lathes.
Should it be even with the elbow height from the floor with the lower arm/hand bent 90°at the elbow. Or some other things that have to be figured in. I plan on standing upright to turn, I have a bench top lathe and before I weld up a frame etc. would like an idea so I can do it only once?
thanks
:clown:
thanks
:clown:
