flippedcracker
First off, all my tools were free, so I'm not complaining about any of them. However, they're Harbor Freight. Enough said, amirite?
Anyway, I have a small drill press, and the spindle stroke is only 2". My lathe also only has about 2" of quill travel (less once the drill chuck is in because of the pin that knocks it out).
Originally, I was using the drill press. I made a jig to act as the table, clamped down the piece and would drill, but because of the short spindle stroke, I had to turn the wood over to drill all the way through. Apparently I couldn't drill exactly in the center because the two holes would be slightly off, and I would get a step on the inside not allowing the tube to go all the way through.
So then I got the dedicated pen blank drilling chuck from PSI, only to find out I'd have the same issue. The travel isn't enough to go all the way through, so I'd flip the blank around but still get the step. I think that has to do with the tailstock not ending up in the exact same spot (since I have to move it away to get the blank out to flip it). Maybe I need to figure out how to line it up better consistently.
After that, I got a self centering pen drill vise to try on the drill press again. same thing, but now I'm thinking the blanks I have aren't prefectly square and maybe that has something to do with it on the vise.
So I'm wondering, do I need to get a drill press that has enough travel to go all the way through, or is there something else I'm missing that I can try.
tl;dr- sorry it's so long. I can't drill all the way through a blank, do I need a tool that can?
