Len Shreck
Hello all I am having a problem and now I am confused. I use 5 min. epoxy to glue my tubes into pen blanks. I glued up 8 pen blanks on the 22th I went to mill them the next night and the mill pushed the tubes right out of the blanks, after the first 2 that this happened to I tried a third and the tube stuck fast to the pen mill and I had to use a pair of pliers to pull it off, this might have been some glue that got on the mill from another one. I thought I might have not put enough hardener in it or maybe too much so I did it again and same results.Now I am very confused what am I doing wrong? I scuff up the tubes on the lathe before I glue, them I use the same 7mm drill bit that I have been using, I am using the same bottles of epoxy I have been using so what am I doing wrong? I ordered extra tubes I used them on the second gluing however I did use the same blanks but I used a Q-tip with some nail polish remover on it to try and get some of the epoxy out of the blanks before the 2nd try. Any help would be very appreciated. I was hoping to have pens made for my family Christmas dinner I am having on Sunday afternoon but now I will not be able to have them done in time now but I still need to know so I am not messing up any more blanks and/or tubes. I keep going over it in my mind trying to figure out if I did something wrong and I know I did it the same way I have been doing it I even had my wife there showing her how it is done, yes I was showing off some, and I ask her to tell me step by step what I did and she went thru it the same way I have been doing it. like it says in the title HELP...
Len
Len
