Has anyone modified a Virage BP Kit ? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 05-13-2018, 09:46 PM   #1 (permalink)
magpens's Avatar
Photos: 75
Default Has anyone modified a Virage BP Kit ?
I want to try some mods to the Virage ballpoint kit.
Just wondering if anyone has already attempted this and what results you obtained if you don't mind sharing.
Specifically, I want to reduce the brass tube diameter for the reason that the existing diameter of 27/64" does not leave much "meat" on the blank. Consequently you are hard pressed to do any creative turning with your blank.
The existing twist mechanism has an OD of about 7.3 mm
Allowing for a tube wall thickness of 0.15 mm (cutting it pretty fine, I know), one should be able to make the brass tube 7.65 mm or so in diameter. This diameter is actually extremely close to the so-called "8 mm" tube actual OD. . Some tiny adjustment may be necessary.
The blank wall thickness would then be (at its thinnest points, the ends), ( 0.474" - 7.65 mm ) / 2 = ( 0.474" - 0.301" ) / 2 = 0.086".
Compare this to the as-manufactured value of ( 0.474" - 0.406" ) / 2 = 0.034" and you see that you can realize a 0.086" - 0.034" = 0.052" increase in the blank wall thickness. . That is a significant increase.
Of course, the transmission fit inside the brass tube has to be considered, as would the hardware connection pieces that hold the tube to the plated nose cone and top finial.
I think it could be done with some careful machining from scratch of these connection pieces.
The architecture of the Virage nose cone and top finial would comfortably allow these mods. The success would rest with skillful machinist skills in making the required parts. . Brass would probably be the material of choice.
Has anyone attempted these mods ?
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 05-14-2018, 10:12 PM   #2 (permalink)
mark james's Avatar
Photos: 481
Default
Ya struck out Mal ! You will just need to try it yourself. But sounds interesting and fun.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 05-15-2018, 08:15 AM   #3 (permalink)
stuckinohio's Avatar
Photos: 3
Default
Mal,
I was wondering if an 8mm tube would slide over the transmission, but it might be a bit too small based on your measurement of 7.3mm. Thought it might be easier to get the smallest tube that fits over the transmission rather than making your own tube.
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Advertisement
Old 05-15-2018, 09:59 AM   #4 (permalink)
magpens's Avatar
Photos: 75
Default
Lewis,
Actually, an 8 mm tube is OK. . I am working with it now. . Will let you know
__________________
Mal
Old 05-15-2018, 08:02 PM   #5 (permalink)
magpens's Avatar
Photos: 75
Default
Mark,
It seems that this is a great opportunity to do something original ....
.... making good progress !
Stay tuned !
Quote:
__________________
Mal
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
