fumanchu314159265
I just finished my first pen and had a problem when assembling it: the hardware was loose in the tubes. I didn't test the fit straight out of the kit, but all the rest of my kits seem to have a nice interference fit. So I'm guessing I drilled out the tubes a little while squaring the ends with my barrel trimmer. I did notice that I had to maneuver the barrel trimmer into the tubes with some pressure and that a spiral had been cut into the tubes with the point of the barrel trimmer shaft as I pulled the hand drill out. Any suggestions for how to avoid this problem of loose fits in the future? Would it be better to drill them on the drill press?
I just glued the tubes for the next round so hope I can avoid this error this time.
Many thanks for any suggestions!
Rob
Rob
