thostorey
I'm very interested in techinques, materials and ideas (I'm at a loss) I mostly turn (to give away) European and Slimline pens.
Tom
Tom
Originally posted by thostorey
<br />I'm very interested in techinques, materials and ideas (I'm at a loss) I mostly turn (to give away) European and Slimline pens.
Tom
<br />Hi Eagle. I'm having a bit of trouble understanding how the various center bands are fixed in place. Are they free-floating between the two blanks
That is the easiest way to turn them .I omit the center bushing(Also omit the mindless center ring)Take a brass tube and punch a hole in 2 pieces of wax paper,put these on the mandrel on either end of the "center band" are they glued to one blank or the other?
When I make a slim line to look like a "Mont Blanc" I turn the general shape and part off a section of the top blank and glue what ever I am going to make the center band out on that. The tube you put in your center bands, are they just the length of the band?
I always buy the ten inch tubes so I have "extras" in emergencies.
Another source is tubes from slimline pencil kits.They are short than pen kits tubes.Since I omit the center band on pencils(I use the 10" tubes and cut them to length)I always have a supply of short tubes. How are they fixed to the rest of the pen?
I see no reason in many instances to glue them to the pen per se.Free floating is fine,It depends on what is easiest an looks the best
Bear with me, I'll get it yet[]
Cheers, Tom
