Hairy Oak problem
Rifleman1776
Mountain Home, Arkansas, USA.
I attempted to make a Jr. Gent from some Hairy Oak I got in a trade from one of our Australian members. Stuff is disappointingly soft. Crushed the first half in the drill press vice. Not too badly, usable with a drop of CA in the crack. But, the second half crushed completely in the vice I use to hold while milling the ends. I'm sure, with special handling, one could make a pen from this wood but my opportunities are now shot. Interesting wood, not the prettiest, but not the worst. Gained an experience. No more HO for me.
Hello
Brattleboro,VT, USA.
why do you put your blanks in a vice for milling? I just hold'em with the mill on a hand drill
I'm sure, though I've heard of hairy oak, that its no softer than a corn cob, or cotton wood bark - which is soft enough to put in your mouth and chew up.
Rifleman1776
I use a machine vise with V-groove inserts. I clamped it down with the same amount of force I use for my other blanks. Yes, if I had known how soft it was, I would have been gentle. I would class it with Balsa.
R2
Brisbane, Queensland, Australia.
Never herad of problems apart from the fact that it can split badly while seasoning. Used quite a bit of it for pens and have given blanks aay to very appreciative recipients. Looks glorious when cut properly,especially on the bias. Takes a wonderful finish. Always had starry eyed looks from those I've given or sold pens to.
workinforwood
Eaton Rapids, Michigan, USA.
I always knew not to use my hands as a vice. I see pictures in magazines where the guy is holding the wood in his hands while milling the ends and it makes no sense to me. I always but one time use a vice, but don't need to squeeze the heck out of it. Just be gentle. That one time I didn't use the vice, well what happened to me wasn't as bad as the nightmare vision I figured would happen. I expected the blank could catch and spin in my hand tearing lots of flesh off, but instead my hand slipped as I was pushing the blank to the mill end and just caught the cutters with the sides of my knuckles and it felt pretty bad even though it was only for a split second. So I'm back doing what I always knew was right and clamping the wood. If you can't get it stabilized, and are truly worried about breaking it in a vice, perhaps some Styrofoam in the vice first and the blank in the middle would help. Lay off the spinach too. ;)
leehljp
Member Liaison
Tunica, Mississippi,
Holding the blank in your hand while trimming can be dangerous to you the operator. I would hazard to guess that within Frank's lifetime (he is older than many on the forum ;)) he has been to the school of experience and hard knocks enough that he has graduated, and now has been accepted in the prestigious school of safety as an instructor - therefore he puts his blanks in a vise! :D
Dario
Austin, TX, USA.
:D:D:D
I too use my vise to hold my blanks and use the DP to trim. That said, I do not tighten it. It is used to stop the blank from spinning and let the trimmer's guide post do its job.
thetalbott4
Roy, Utah, USA.
I've turned a lot of Hairy Oak and have never found it to be very soft. In fact I have 12 blanks now that I went out and checked and none of them are soft. I'm thinking you just got ahold of some punky material. It's been a real consistent seller also. People seem to like the look. Consider trying it again. I sold a Hairy Oak Emperor for $280 and the buyer set the price!
wdcav1952
Activities Manager Emeritus
Even as a teenager???? [}:)][}:)][}:)];)
