12.5 mm guide rod and first Atrax
Hi Folks: I wound-up oversizing the length of the cut, not drilling the whole way thru (after blowing two blanks attempting to drill thru it), gluing in the tube using thick CA, then trimming small amounts off of the closed end until a 5 mm hole appeared. Then I sanded (trimmed both ends of the barrel) using my lathe (80 grit) and the HF transfer punch (I guess it was about 12MM). Worked out well. I didn't enjoy by Malachite tru stone experience. The 10.5 mm side went well, but the 12.5mm was a PITN for me (all about patience...some day I will learn). Here what it looks like. I would give it a "B". Really a C- if you count the two short blanks that I blew. Thanks for all of the advice. I really do like the Atrax. Funny, I bought the blanks 1 week into penturning (at a WW show in Atlanta) and two weeks before buying my lathe. I had no idea what I was buying. On to my DC system. Despite organic mask, shop vacs, and hood, that blank made a lot of dust which managed to get into my lungs. Thanks again! It looks that Jet DC 1100 VX may be the right way for me to go.
