Gouge Preference?
Mikey
Cleveland, OH, USA.
I think I have the type of gouge you use and I also find it does a wnderful job in not only wood, but if you turn it sideways, it makes great cuts in all sorts of resins. I use a few other tools, but none get the same amount of use while making pens.
I like a round nose scraper for most of my wood pens... I used it for acrylics until I read Ed Davidson's post about using the skew... now I will round the blank with a scraper then switch to the skew to finish the cuts. I sometimes usa a spindle gouge is good to do very light finish cuts..
bradh
Aurora, Ontario, Canada.
I have used a spindle gouge for turning pens. I prefer a skew, but the spindle gouge is a little easier to learn with.
The spindle gouge is good if you want to do some bead work on the pen.
Brad
LEAP
Old Orchard Beach, Maine
After watching Alan Lacers skew video I switched from the spindle gouge and now there is no going back. I find the versatility meets all the needs I have. Prior to watching the video I was "scared of the skew" I had had some major catches doing spindle work when I first tried one but found it was a case of technique and using too small a tool for the job. Now I hardly ever grab another chisel when doing a pen.
bnoles
NW Georgia USA
Brian,
I have the Kip and Rex gouge and really like it. I use it to get the pen roughed down and then switch to the skew for clean up. The combination of the 2 tools works great for me.
Dario
Austin, TX, USA.
I've reached the point where I can turn a pen using just ONE of my tool (bowl gouge, skew, roughing gouge, parting tool, scraper, etc.) if I wanted. BUT it won't be the most efficient way (for me) to do it so I don't.
I predominantly use both my roughing gouge and skew 99% of the time on all my pens. It all boils down to what best work for you [:)].
kent4Him
Paddock Lake, WI USA.
I use a gouge with the Irish grind. Far up the flute as I can go. I occationally use a skew, but I do mostly woods. For the few acrylics that I have done, the round nosed scraper is the best for me. On antler, I use a gouge until round and then I use the skew, but only as a scraper.
As you can see, there are many answers to this one question.
