Gluing up Staron (Similar to Corian) Material
lapdog
I have access to alot of 1/2" Staron solid surface material. Should the pen blank glue-up be shiny side to shiny side or dull side to dull side. I found some instruction on the internet but it did not clearly answer this question for me. I am interested in minimizing any visible seam. Thanks for any help.
Parson
Houston, Texas
Each of the solid surface material makers has a special two part color-specific epoxy kit they use to create very tight seams that don't show. I've tried to sand and glue up corian for a pen with CA and it still showed a seam.
Of course, you can use alternating patterns and solve this problem. But if you want seamless material, you may want to buy that kit.
hewunch
Albany, GA
Using CA do shiny to shiny. Scuff it up a little with 150 grit, clamp well after the glue is applied
DozerMite
Banned
It's not inexpensive for the gun required for the factory adhesive, usually a couple hundred just for the gun.
Just sand some of the material and mix the dust in some epoxy. Doesn't really matter which surface you use, since the colored epoxy fills any imperfections.
If there is a pattern in the material, it will always show to some degree, because the pattern doesn't match up.
AceMrFixIt
Jacksonville, FL
I made a plunger out of 2 different size dowels taped together and it works well for the factory adhesive tubes. Gluing the smooth sides together with ca works well and has minimum seam.
JohnU
Ottawa, Illinois
The problem with CA, in my experience, is there is a potential to your seam cracking if the tube and hole are tight when gluing. There is no give with CA. I think I would try the epoxy with some color close to the material. good luck
Parson
Houston, Texas
Mine cracked when using CA, although I might try mixing dust from the color in it and trying it again.
The two part can be mixed and applied like normal two part epoxy. No gun required.
bgibb42
Hull, GA
Has anybody tried regular epoxy with some sanding dust or a small amount of similarly tinted paint mixed in?
jeffnreno
Reno, NV, USA.
How I Glue Corian
I have had success with Corian as follows.
1. Clean shiny sides with denatured alcohol.
2. Apply medium ca glue to shiny side of one blank.
3. Rub other side shiny side to shiny side to evenly coat both blanks.
4. Clamps as may clamps as possible - i.e. right next to each other.
5. Allow to set overnight.
6. Cut blank a little long.
7. Drill blank for tube and do not drill all the way through
(I have split the blank when drilling all the way through)
8. Cut the blank open on tablesaw.
9. Glue tube in - square - turn - finish
lapdog
Jeff,
I just finished my 1st Staron attempt using most of your procedure. It came out great. The seam entirely disappeared to the naked eye as soon as I started turning (before even polishing). The only difference that I did was the following:
I put plenty of medium CA on each half and spread it out using a piece of wax paper. I then put the (2) pieces together, wrapped the whole thing in wax paper and clamped.
I am looking forward to using this material again.
Thanks for your help.
shadow man
Nashville, Tn
I am lucky we make solid surface as well as granite, marble, and laminate countertops in our shop so I have the factory adhevises to use. The trick is to use as many clamps as possible. The tighter it is glued together the less likely you will be able to see the joint after it is turned. The best clamps I have found are the 2" aligator clips. Home depot in my area has them for .99 cents apiece.
Good luck
George
jeffnreno
Reno, NV, USA.
Jeff,
Glad to help - Post a pic of the pen if you get a chance.
