We had a saying in dental school that applies here:
This method works best in MY hands
Frankly I get a bit tired of people saying their way is the best and other ways don't work. It is not just this thread. People who end mill with sanders say pen mills don't work, others say you must use micro mesh with the pads since the strips don't work. Then of course, there is the wet sand/dry sand discussion.
All of the glues mentioned in this thread will work if used CORRECTLY!! As Ed said, most "catastrophic" failures are the result of momentary inattention. It can be inattention with a turning tool, or inattention to detail while gluing tubes in a blank, or inattention while drilling, resulting in a fit for the tube that is too tight or too loose, both of which can cause failures.
Find methods that work best in your hands and use them. Let others find what works best in their hands, be it over or under kill.
End of rant.
