I have switched from CA to Gorilla Glue for the pen tubes. I have noticed, a few times, that the glue doesn't seem to hold on some acrylics.
Dan; I sometimes use CA, sometimes gorilla glue (PU). PU fills gaps well, CA does not. PU sometimes pushes the brass tube out of the blank, CA does not. CA hardens quicky (sometimes TOO QUICKLY!), PU allows you adjustment time.
Rough the brass tube surface with sandpaper or crocus cloth (plumbers cloth) before using either glue.
Run a gun brass brush through the blank before assembling.
With PU and acrylic, spray the tube ends with water after inserting the tube into the blank.
Plug one end of the brass tube with wax, play dough, or a potato. Put a dollop of glue inside the blank and more glue on the side of the brass tube closest to he plug and insert with a twisting motion. If you have used enough glue, the glue will squeeze out in a complete circle on the far end of the blank.
We use so little glue for our pens that the PU will probably go bad by the time you have used most of the bottle and I only buy the smallest size available.
TIP: The PU will form a "skin" on the top surface of the glue. To eliminate this, drill a hole into a small piece of 2x4 and put the capped bottle into the hole upside down.
