Gluing cigar wrappers to brass tubes, etc - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-19-2018, 01:03 PM   #1 (permalink)
Photos: 0
Default Gluing cigar wrappers to brass tubes, etc
Hi all. I'm looking to make pens using real cigar wrappers, using cigar leaves I'll glue to tubes, cast in alumilite clear, then turn. What type of glue would you recommend for this? I saw a video where it looked like the person was using a white (elmers type) glue. I think CA would be to messy.
Markus666 is offline   Reply With Quote Top
Old 12-19-2018, 01:11 PM   #2 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Sounds like a Modge Podge application to me.
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 12-19-2018, 01:42 PM   #3 (permalink)
jxdubbs's Avatar
Photos: 0
Default
Yeah I'd 2nd that modge podge
Sent from my SM-G930V using Tapatalk
jxdubbs is offline   Reply With Quote Top
Advertisement
Old 12-19-2018, 01:56 PM   #4 (permalink)
Photos: 1
Default
I use Elmers on painted tubes. After it dries I brush on a coat of watered down Elmers and let it dry. Modge Podge would probably be better than diluted Elmers, it has more body and will build thicker. I moisten the leaves with water to make them wrap better, so you will need a water based adhesive, collagen based glue might be a very good choice. . . if you happen to have a dead horse lying around.
I cast them in poly resin because I like more shine than I get from urethane. Slow drying poly resin tends to saturate the tobacco leaves and turn them grey, so the top coat is needed. Aluminite may not do that as much and therefore you may not need the top coat.
__________________
Often wrong, never in doubt.
Chasper is offline   Reply With Quote Top
Old 12-19-2018, 03:08 PM   #5 (permalink)
Photos: 0
Default
Thanks Chasper. Horses I have, though unfortunately (?), they're not dead! I picked up a gorilla glue spray previously, but it's pretty thick stuff. Is Modge Podge thinner?
Old 12-19-2018, 04:29 PM   #6 (permalink)
Photos: 1
Default
Mod Podge has some thickness, but you would only need one or at most two layers of it to protect the tobacco leaves from the resin. I've used one layer of diluted Elmers and it was enough to keep the resin from saturating and discoloring the tobacco leaf. Mod Podge would definitely be better than diluted Elmers.
__________________
Related Content
Reply
Bookmarks
Tags
cigar pens , glues
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
