jhawth25
When gluing blanks, do you use wood glue or CA?
I do use CA glue on some segmented and laser cut blanks - however my go to glue for most of the wood/stone/acrylic pens I make is the Gorilla Glue that expans. Meaning - put the glue on the tube, put your blank in water for a few seconds - take the blank out of the water and insert the tube. The glue dries slower than CA glue so you have a little time to work with it. As it dries the glue will expand into a foam - filling any voids in the blank and really reducing the likelihood of blowing the blank out when it nears completion.
Enjoy!
Enjoy!
I would not recommend putting the wood in water. Increasing the moisture content of the wood can cause later problems with the finish.
There is enough residual moisture in wood that you dont really need to add any for gorilla glue to set, but if you feel you need to add water, a damp q-tip inside the hole will add the moisture in a much more controlled way.
For the various acrylics, yes, I wet them down first.
