Glueing Tubes in Nickel Plated Casings
gerryr
Billings, MT, USA.
I've made quite a few casing pens using regular brass casings and slimline kits. I put a short piece of heat shrink tube on the end of the tube to fill the gap for the nib and use CA to glue it all together. Rarely, I have one come loose. Last night I was making some with Nickel plated casings I got from Royce in the group buy. Every single one of them, three, came loose at least once. Is there a trick to using the Nickel plated casings?
mrcook4570
Mason, WV, USA.
I had quite a few failures with CA - not just with cartridge cases, but also with aluminum and wood, so I quit using it. I've been using gorilla glue for over a year now and haven't had any problems. It also expands to fill the gap in the case so there is a bond the entire length of the case, not just at the neck and head of the case.
dfurlano
Avondale, PA
Using a 2018 arrow inside a 30 caliber casing is a press fit. Then I CA glue the brass tube inside of the arrow and it has worked very well. Need to rough both surfaces.
alamocdc
San Antonio, Texas, USA.
Don't know about nickel plated casings, Gerry, but I drill and glue a short piece of scrap hardwood or acrylic to the end of the tube and turn it so that it is just a press fit. It looks somethign like this:
<br />
NOTE: This is not to scale.
knottyharry
Wilkes-Barre, PA, USA.
Hi Gerry,
I clean the inside of the crimped end with some sandpaper, or the small carbide bit I use in my dremel tool.
I use the gel type CA....and I have never had one come loose.
Maybe it's the glue...when mine starts to get down to about a 1/4 of the bottle left it seems like it wants to plug up in the neck of the tube, and I pitch it and go for a new bottle.
But I know others have good luck with the various types of glue also.
Harry
