ctubbs
Hi all,
What is the best way to put glue inside the hole in the pen blank when using a thick glue such as epoxy? I always get way too much in the hole and it comes out the other end when I insert the tube. Then I have this glob I have to clean when I square the end of the blank. I have tried using a tooth pick, Q-tip and not putting glue in the hole at all. The last one allows the wood to spall off the tube on slim line tubes.
I have tried CA, thin, thick and medium. It solves the gob problem but I still have the problem of the wood not sticking to the tube.
Yes, I do scuff the tube before applying the glue.
Any suggestions will be tried.
Thank you for your help.
Charles
Charles
