jtj
On the acrylic blanks I have turned, I can see the glue smears. These were gifts, and the recipients thought they were great, but I can clearly see the glue streaking or voids and, of course, they look degraded to me because of this.
1. Is painting the inside of the tube the answer to eliminate this effect.
2. The brass of the tube in these blanks seemed to be a good color match for the blank, but with the voids in the glue, they look inconsistent to me. Is it a problem with not enough glue.
3. If painting is the solution, what colors have you found work best. Is there one that you would use to match a brass look. Do you stock a selection of colors to try to color mix.
4. If you paint do you thin the paint?
5. If you paint, do you go for opaque?
I did try to search for glue smears, but not a hit that seemed to discuss this phenomenon.
Thanks, JT
Thanks in advance.
Thanks, JT
Thanks in advance.
