I switched from CA to epoxy because we had several instances where the CA loosened while turning or in use. I am using a 5 minute epoxy; but, now think that 12 hours or more are needed to let cure. I have had 2 instances, one yesterday, where the epoxy has had about 2 hours to cure and still loosened. I am impatient today and so used CA to reglue the tube and will be re-turning in a minute to see if it holds.
