AnachitlPut
My shop teacher wanted to know what glue to use for acrylics. He had proplems with using ca due to the barrel turning after it's glued.
I use Epoxy. I think the issue w/ CA is the lack of air and moisture in the acrylic keeping it from curing. W/ Epoxy you don't need that because you are mixing the hardener right in.
