Warren White
A few newbie questions, if you don't mind....
First, how do you know whether or not you need to paint the brass tube or the inside of the blank? I have included a picture of an acrylic blank I am going to turn. It isn't transparent, but I don't know if the tube/blank needs to be painted.
Second, if it should be painted, I would assume for this blank it should be painted white. Is that right?
I just don't know how to determine beforehand whether the brass will show through.
Third, should I use my small desk sander to take the corners off before I turn the blank, and can I use the same technique for squaring off the end as I do with wood (a sanding disk attached to the headstock of my lathe)? I have never sanded acrylic, and I don't know what to expect.
Thank you SO VERY MUCH for all of your help! This forum is great!!!
Warren
Warren
