Steve Busey
A month or so ago, before some stuff hit the proverbial fan, I was making a new Jr Gent with one of Constant's red dyed burls and a new set of johnnycnc's bushings. Didn't really pay much attention at the time, but in restrospect, there was a little wobble in one of the bushings. When I pulled the finished blanks off the lathe, one of them was visibly out of round (ie - the wood was thicker on one side of the tube than the other). This of course would cause mismatch with the pen kit hardware.
In a panic, I shot off an email to johnnycnc, trying to see if I could get a replacement bushing, since my first thought was that one of the bushings was out of round. (Having used John's bushing before, I should have known better, but for several reasons, I wasn't thinking straight...).
He replied that all his bushings are tested before they head out the door, and suggested I check a couple of other things. He also offered to send a replacement on his dime.
Well, as you might guess, the problem was not the bushings, but the idiot behind the lathe. It started at the drill press, where I couldn't drill straight through the blank, then got exacerbated at the sanding disc, as I squared the ends to the blank, not the tube. So when I plugged in the bushings and tightened up the tailstock, the bushings were forced at an angle into the tube, causing the above mentioned wobble, and the OOR condition.
John showed grace throughout our exchanges, helping me understand the pitfalls of squaring the ends.
I'm still trying to find the best way to square my bigger blanks (to the tube), but at least I know where the problem lies now - and it clearly is NOT johnnycnc!
For all this, John Goodin is a Gent, but (AFAIK) not a Jr!
