Gear Shift Pen - Experience ?
TonyL
Georgia
Hi Folks:
If anyone has direct experience with these: https://www.pennstateind.com/store/gearshift-pen-kits.html
I would like to know what you think (basically: "I had no trouble with them." or "I have had trouble with them" )
I don't make many novelty pens (not that they are "bad") anymore, but a client and friend picked-up my PSI catalogue and wanted one. I thought I would ask "the greater intellect of the IAP" for their experience.
Keep in mind that I really don't sell pens to make money - so I prefer zero aggravation if I can help it.
Thank you as always!
OK-Pens
Denmark
I have made a few of them with no problems, and use one my self on a daily basis. The only thing I have had a problem with, is that the cap on my own is lost so I would advise to secure it with glue.
David350
Dallas, TX
Hi Tony, I have made about a dozen of these for family and friends. I typically ask for their favorite car color and find a blank in that color and they all loved the pen. I have had no issues, it's an easy pen to make, but will second the suggestion on securing the cap.
I had shown this one recently that I made for a friend. Just gave it to him a couple days ago and he liked it. It was the only one I ever made and had no trouble with it. The shifter works OK how does it hold up, for me it will be a matter of time yet. I do not make gadget pens either but this one fit the bill.
duncsuss
Wilmington, MA
I've made a couple, because I was using Fordite as the barrel I sanded down the couplers to make them a slip-fit and glued them in place.
TonyL
Georgia
Thank you all very much, especially for sharing photos of your o/s work!
I just had 15% off, but I think the 3 or 4 starter pack is on sale (not that I need any more drill bits).
Thanks again! This is such a wonderful forum.
coulcd
Geneva, IL 60134
I've made a couple. The only issue I've run into is that the gear shift knob orientation is not correct from the factory. There is a set screw inside the upper assembly that needs to be loosened and then the gear shift know can be rotated.
magpens
Canada
Personally, I don't like the Gearshift pen. . Here's the reason.
The bolt action mechanism to advance/retract the refill has 6 physical "stops" for the "activating lever or button". . In terms of function, these amount to only two effective positions : refill-advanced and refill-retracted. . There is a middle "stop" (which amounts to two "stops" because of the layout). . This middle "stop" serves no function, except as a mid-point between the other two. . These two positions for the lever/button should have been physically blocked in such a way that the lever/button could not go into these positions and just slide past them. . But ... because the lever/button CAN go into these positions, it often DOES ... and that is frustrating because they are useless positions, and allowing the lever/button to stop in these positions means that extending and retracting often becomes a two-step, or two-stop, process. . In fact, not just "often", but "nearly always".
I know, I know ... 6 positions are meant to emulate a 5 + Reverse gearshift ... but so what ... this is a pen !!
"OK, OK!", you say; "if it sells that's good." . Not for me. . Sooner, not later, the buyer is going to get sick of the hiatus between Advance and Retract.
This kit is the epitome of gimmicky pen kit design !
The 30 Caliber Bolt Action design is a great design. . This Gearshift design is just taking a good concept ridiculously too far.
Monty
Group Buy Coordinator
Pearland, Texas, USA.
My personal feeling exactly. The pen needs to be completely extended or retracted.
As to the overall function, I have made a few of these per request. Have had no problems that I am aware of.
WriteON
Florida & Pa
You'll enjoy these. Great single barrel pen. Nothing negative about them. No aggravation with them. They are quite sharp looking. Well made & designed. Advancing and retracting is simple and easy. Very much appreciated gifts to car guys. I do not sell pens. Was in a jewelry shop and had one in my pocket...a person asked me for 3 and loved them. Got good $$ for them.
WriteON
Florida & Pa
Nice looking Gear. The shifter holds up great. Unless it's severely abused there is no reason for failure. No twists, no clicks. Advance and lock up. I sold a few and gifted a few. I provided a single pen stand with a lug nut glued to the base. I'm now certain peoples best friend.
Here's before the lug nut was glued. The flag went to a friend in Texas...we belonged to a car club together. Sorry about the pictures.
Tucson, Arizona
I have made quite a few and have sold many as well. Very neat pen for someone who prefers the novelty over the slight impracticality of the mechanism.
WriteON
Florida & Pa
Guys...Do you drive a 5 or 6 speed? This pen is an absolute great novelty pen for those that do. The clip is a pry bar. It has wheels and tires on it. The Gear is first class cool and a great conversation piece. As for it can only be only advanced or retracted? Every pen I have is either fully advanced, retracted or fixed. I love this pen... I think it needs a clutch
turncrazy43
Marietta, GA
Tony, I have made and sold several of these pens. They are easy to assemble and none have had problems. The thing I noticed is that PSI offers them in several metal finishes. However, I grew up in the muscle car era and don't recall any wheels and trim in antique brass, gun metal or antique pewter. Chrome is the one I recall the most. All of the ones I made and sold were done in chrome and I believe are the most true to the era. Good luck with yours.
Turncrazy43
TonyL
Georgia
Thank you all. In general, they sound no more prone to problems than other kits. I am going to buy the 4 pack. Thanks again!
